Hi,
I have just created a new project with one system. Now, I want to add an evaluation map. However, following the advice according to
How to upload evaluation maps - Support - Geodesignhub Community
the map to where I should add the evaluation map in the GEODESIGN just does not show up. What should I do?
Regards
Fred
Hello Fred, Thank you for your message. By default the evaluation maps section is turned off, you w will have to turn it on. See instructions here.
Thank you very much Hrishi. Forgive me my ignorance. It became obvious that I was not using GeodesignHub for quite a while. But this will change now.
Hi Hrishi,
I think this time I did everything in the right way. Still, I cannot upload the evaluation map. Would you mind to take a look on the data?
Regards
Fred
